What model number?
Hi,Does anyone know where to buy the 12 vdc plug that is on the power supply that comes with most of the Panasonic Camera's? I have a camera without a power supply and just want to run it off a regular 12 vdc supply anyway since it has battery backup etc.
I am assuming you are in the U.S. If so then the easiest (but not the cheapest) place is probably your local Radio Shack. You will need something like this. There are a few different sizes so the best idea is probably to take your existing power supply or camera with you and compare.
Paul
Hi,Radio shack does not carry the connectors with the center pin (its just not a straight barrel type connector that is commonly used). I think Panasonic went to a slightly unique one so that people do not use power supplies other than there own.
Sorry I didn't realise that. My Panasonic camera uses a standard DC barrel connector and it uses the same model power supply (although googling indicates that there are quite a few different suffixes for that power supply).
They must have changed the connector. Is it the type that has a socket in the middle on the camera and needs a pin inside the barrel on the plug? Like some new laptops use?
Paul
I think I may have 3 of these from a recent install I did using some videoalarm housings. Can you post or PM me a pic?
They came with a housing that has a universal setup and are not needed for tha application I am using them for.
I actually found some online for about $2 a piece. I will give them a try tomorrow.
Where did you find them? I don't need any at the moment but I have these HCM cameras and you never know.
Minutemen Part #2559. I will give them a try tomorrow and let you know how they work out.
