HAI Program a status for use with APP
MSTIMMELL
Question looking for ideas How to program a status that I can see on my Phone APP
Garage Door has Sensor so how do I set a status that shows me on the App if I garage door is Open or Closed..
thanks.
You'll need to make sure that wire is hooked up to the board. Then you need to add a Zone named "Garage" in PCAccess based on the zone it's wired to. After that, you should be able to see it on the App etc, once you write the update to the board. If you need help, PM me and we can go from there.
I found a solution.. I added a X10 unit to my system M1   Then programmed the Garage door Contact  to turn ON if Closed and Off if Open.. Excluded it from All ON/OFF   since this is the first unit it now easy to see if the Door is closed when I'm away from Home on my IPhone Snaplink App..   I already can open Close the Door from HAI/Lutron Scene Call all is good now   thanks for the input..
Mark
