mhouser03
I have a client who's asking me install FOUR CCTV cams in a variety of places, in a home that's already built. I can run a few wires .. but figure I WON'T run any instead, and would like to pair up an NVR with some cheap-o FOSCAM (FI8905W) WiFi/IP cams, such as shown here: http://www.bhphotovi...ireless_IP.html
This way I can locate them just below the ceiling, above a power outlet and fish the wires inside the wall, down to the outlets and plug them in.
Someone has suggested that I use Ethernet over power, or attach a wifi/extender-hub at the location - which could be useful in a pinch, i suppose.. but the client isn't interested in seeing a shelf with a buncha devices on it at the camera locations.. . Could still end up needing wifi-extenders to relay signal to the router/nvr.. but my main concern is IP compression compatibility with a network recording device.
This cameras output is MJPG
I understand that this camera boasts 'Built-In Network Video Recording System'
(256 MB min / 1.0 GB recommended), but i don't trust it to be the recorded-solution I should rely on.
This cameras output is MJPG, but I've been warned by others that NVR's can be more particular than just matching IP Compression formats, and that I *should* referr to manufacturers 'supported IP camera models' - 'else risk trial and error madness.
A stand alone WiFi/IP CCTV (w/power only), NVR compatible solution is what i am looking for.
Something where the only wire at the cameras location is power.
Like this example:
Power wire goes in the wall and drops to the power outlet, directly below it..
And a compatable NVR can get the images for archiveal by visiting the IP address fof the individual cameras..
Camera #1 = 10.0.1.101/image.jpg -saved...
Camera #2 = 10.0.1.102/image.jpg -saved...
Camera #3 = 10.0.1.103/image.jpg -saved...
Camera #4 = 10.0.1.104/image.jpg -saved...
Seems none of the distributors, nor any of the manufacturers say their devices will work together.. or atleast those who do list 'supported devices', don't seem to have anything I can sell to this client. Some have even stated that not all MJPEG formats are the same..
I've been calling around all day.. seems the closest thing I can get, is a 2.5G non-wifi system such as shown below:
And with this system, the distributor suggests that i purchase two directional antennea, and seperate the recievers by a few feet for proper performance. This does NOT sound like my solution. Help me scoobie doobie canoobie, you're my only hope.
Like this example:
