My shop has two regular sectional garage doors. Neither has a GDO on it, mainly because there aren't any cars parked in there. Many times, I will manually close the garage door without locking it when I leave it for a short period of time (usually to keep critters out of it). For example, if I am mowing, I will back the mower out, close the door but not lock it, then go about mowing the yard. Or, I may close the door but leave it unlocked thinking I will be back in a few minutes, but get sidetracked and not go back for a couple of days.
The door has the typical lock mechanism -- two horizontal bars that when locked go thru holes in the tracks. When locked, the bars extend thru the hole an inch or so.
I would like to have my Elk notify me when the garage door is unlocked. The actual notification method (voice message, indicator light, etc.) is not important right now. What I need to find is some way to detect when the door is not locked. I think the best solution would be some kind of mechanical dry contact device mounted over the hole in the track. When the lock bar extends thru the hole in locked position, it would mechanically open the dry contacts. I may couple such a device with a regular garage door open/close sensor so I can differentiate between unlocked/open vs uplocked/closed.
Has anyone seen such a device, or something similar that could be modified to work? For the most part, I would rather buy (and modify if necessary) than build.
Ira
Ira
