Deane Johnson
Possibly not. In the Universal Devices Administrative Console, I get an error message that internet access is turned off. I try and "enable it" and it fails.
How did you assign it an address if you can't connect?Deane Johnson said:With the reboot without the PLM, I now have a steady Rx blue light in addition to the power blue light. I still don't think I'm connecting to the ISY, though it was assigned an address right at the beginning of the evening.
I am not familiar with Safari much.Deane Johnson said:Safari can't open it because the server can't be found.
If you don't log in to ISY you cannot access anything. You need to log in first. Perhaps you need to place the cursor in the login text box for the keyboard to pop up?Deane Johnson said:I found the blue screen with Safari, but the keyboard didn't pop up so I didn't log in. Probably no reason to from the iPad as the only thing it is used for is a CQC client.
You never stated you had a PC. You only mentioned an iPad.Deane Johnson said:It requires java 2 which I don't have on the iPad. I'm trying to understand why I want to log in from the iPad. What's wrong with my PC? The PC I'm on is completely separate from my CQC server and of course, the ISY.
LarrylLix said:The username, password and IP address will need to be set to match CQC for the Rest interface to be used. Is there a place in CQC to set those parameters?
The ISY uses security to block random access to it and CQC will need to use encrypted security to control things.
