Reading through the ELK manual, it says that the M1 stores its "operating firmware in Flash memory." I've assumed that this meant that only the firmware is in flash, and the configuration information was elsewhere (e.g. in non-flash memory that requires battery backup). But now I wonder if this is also stored in flash.
What if you try doing a reset of the entire panel back to factory defaults from the Global System Defs menu, G45?
