ok - i'll buy that... so basically, let the DMX on the RG resolve to the router's wan IP which inturn opens either dmz or port forwarding to static on the elk?
Here is how the "non DMZ" approach works. As I noted earlier, I may move my router to the DMZ zone. From what I understand, the DMZ only allows a single device in the DMZ and it routes all non TV traffic directly to the device in the DMZ. The RG does some limited filtering but the device in the DMZ will essentially see all traffic including bad stuff so that device must be able to handle everything just as if the RG was not there. In this mode, I think the RG is essentially acting as a modem in the same way you have a modem for DSL. There are ways to put multiple devices behind the RG where each is tied to a static public IP address but I don't need that and have not dug into that area. Try the following steps:
- Use one RG LAN port to feed the WAN port on your router. Remaining RG LAN ports feed your TV's.
- Setup your router to get a DHCP address from the RG. You MUST have your router's LAN set to a different subnet from the RG. The RG uses the 192.168.1.x sub net and you cannot use that sub net for your router. The RG uses 192.168.1.254 for itself. I have my router subnet set to 192.168.2.x. Change your router subnet and save your settings
- In the RG, use the MDC menu (Local Network > Configure), uncheck the block at the bottom that causes a warning for router behind a router. This is the step I noted earlier that I expect to change if I move my router to the DMZPlus zone. From other forums I think I saw that if youhave this checked, it will cause a warning window to pop up which gives you the option to put your router in the DMZ at that point. I have not tried this yet.
- reboot your router to pick up a DHCP IP from the RG.
At this point, when you look at the IP addresses assigned by the RG, you should see the DHCP addresses assigned to your TV's and your router. May need to look at MAC codes to determine which address is your router since it does not show any names. Alternately, unplug your TV's and your router should show up as the only device on line. To check everything out, plug in a computer to your router and let it get a new DHCP address from the new subnet controlled by your router. If all is well, your computer should have a DHCP IP address on your router subnet and you should be able to surf the net. Also, your router should show that it is attached to your public IP address.
At this point, you will need to set up the rest of your private LAN (all connected to your router) in whatever way you desire including assigning a static IP address to your Elk. I reworked my router network before Uverse was installed because I knew I would have a subnet address clash.
