I have a similar size house and 3 floors but I now have 3. Do I need 3? Yes and no. If I was only worried about solid WiFi coverage, 1 of the UniFi AC Pros would be fine. But I also want strong 5 GHz coverage (faster but shorter range) and I’m also trying to cover a little of the front, side, and back yards. So I have an Inwall AC Pro on the middle floor back and a pair of AC Pros in the front left and right of the upper floor. To say I have full coverage and extremely fast speeds is an understatement. Just thought I’d share as it is a solid design worth emulating with the caveat that every situation is slightly different.batwater said:I have the Pro. It's priced well on Amazon. How many square feet, how many stories is the house? I'm running 1 with our 2500 square foot home 3 stories, located on middle floor center of the home in a coat closet. Average about 22 devices on WiFi at all times.
neillt said:The Ubiquitis also talk to each other, and will force the devices to roam back to better APs. The management interface is excellent at showing what devices are on what AP, and what their signal strength is.
dgage said:The device decides when to switch, the Fast Roaming just makes sure that handoff is fast. This is why some people do a wifi signal analysis and reduce the power on the APs so they don't overlap (much) and so the device will switch more readily.
carealtor said:This seems to be a contradiction, no?
upstatemike said:I think I will hold off changing the network for now and focus on issues in the clients. I have reserved IP addresses for every device to eliminate the chance of network storms from duplicate IPs but I notice there are still UPNP storms sometimes between my Sonos components. Maybe my best network improvement will come from reducing or eliminating the Sonos devices connected to it.
upstatemike said:when they go crazy they flood the entire wired and wireless network with traffic just like any other network device that is misbehaving.
upstatemike said:Thanks but I don't need a Bridge as several of my players are hard-wired (less than I used to have due to STP issues). You only need a Bridge if none of your players are near an Ethernet jack or if you want to run off Wi-Fi. Running in Bridge mode saves Wi-Fi bandwidth contention on my APs but otherwise does not help my network issues since the players and controllers all consume IP addresses and when they go crazy they flood the entire wired and wireless network with traffic just like any other network device that is misbehaving.
neillt said:This is a well known problem. I was in Lutron training a few weeks ago and we spent a good hour just railing against Sonos creating massive network loops and crashing RadioRA and HomeWorks processors.
