dBeau
I have three ECM-1240's watching over my breaker box. One channel monitors the load on the way into the breakers, then I have a CT on each of the 48 circuits leaving the box. The ECM-1240 Engine software has a cool feature where it subtracts all of outgoing loads from the incoming load and displays the result as "un-monitored".
In theory, this makes great sense. If the entire panel is monitored, this value should be zero. If not, it's an error either in the wiring of the CTs (ie something is not being monitored) or in the calculation of the total load. Watching the display reveals part of the problem as un-monitored spikes whenever a load that is monitored by a unit other than the one watching incoming load turns on. The time difference between polling the units creates an artificial imbalance between what is coming in an what is going out. That imbalance quickly corrects itself as soon and all units have been polled.
What I cant explain is the constant 100w un-monitored load I am seeing. I've checked and double checked all my connections. For each CT the monitored value goes up when a load comes on. So the wiring looks all good. Is a 100w error reasonable here? It's between 5%-10% of the typical load. Is anyone else monitoring all of their circuits and seeing something similar?
