purchased a used M1 Gold and am not able to get into any programming to add the ethernet module.
The seller says that they have not done anything except add users since they purchased from another entity where it was also in use since 2009.
Therefore it has probably not had any upgrades since then at least.
The code the seller gave me seems to be the master code.
When I put that code in and hit Elk Button and 9 it beeps at me and says AUTH REQUIRED.
When I put in the default installers code and do the same the behavior is a little different. It still beeps with a low tone but the screen changes so fast I cant tell wether it says auth required or not.
It is accepting the default installers code since I can change user codes and such but wont let me into menu 9.
When connecting with RP2 it says access code or serial number is incorrect. I am using the default access code and have tried every other code the seller gave me to no avail.
With this unit not being updated in so long could it be that it has older firmware and different default codes?
I am trying to Use RP1 but am having issue with a dll error when i try to connect. Do you guys think I would need to access with RP1? Is the default code any different with this?
