C
chucklyons
Guest
Using my jqm? You're doomed
2015-01-25 11:06:56,936 [5] INFO - [PremiseWebServiceSVCLogger] Premise Web Services OnStart command received. Worker thread starting
2015-01-25 11:06:56,946 [5] INFO - [PremiseWebServiceSVCLogger] Premise Web Services worker thread started
2015-01-25 11:06:56,958 [7] INFO - [PremiseWebServicesDriverLogger] WebServicesDriver Server method started
2015-01-25 11:06:56,972 [7] DEBUG - [PremiseWebServicesDriverLogger] Found IP Address: 192.168.0.210
2015-01-25 11:06:56,972 [7] DEBUG - [PremiseWebServicesDriverLogger] Found IP Address: 127.0.0.1
2015-01-25 11:06:56,996 [7] INFO - [PremiseWebServicesDriverLogger] WebServicesDriver ServiceHost created using service URL: net.tcp://Holly:8888/PremiseWebService
2015-01-25 11:06:56,996 [7] INFO - [PremiseWebServicesDriverLogger] WebServicesDriver NetTCPBinding created
2015-01-25 11:06:56,996 [7] INFO - [PremiseWebServicesDriverLogger] WebServicesDriver ServiceHost endpoint added
2015-01-25 11:06:56,996 [7] INFO - [PremiseWebServicesDriverLogger] Starting metadata service on: http://Holly:8889/PremiseWebService
2015-01-25 11:06:56,996 [7] INFO - [PremiseWebServicesDriverLogger] WebServicesDriver ServiceHost opening...
2015-01-25 11:06:56,996 [7] DEBUG - [PremiseWebServicesDriverLogger] Service opening event received
2015-01-25 11:06:57,016 [7] DEBUG - [PremiseWebServicesDriverLogger] Service opened event received
2015-01-25 11:06:57,016 [7] INFO - [PremiseWebServicesDriverLogger] WebServicesDriver ServiceHost opened, waiting for clients
2015-01-25 11:06:57,016 [7] INFO - [PremiseWebServicesDriverLogger] WebServicesDriver starting subscription checker timer
2015-01-25 11:08:46,298 [17] INFO - [PremiseWebServiceLibLogger] PremiseBroker::Connect called for holly with Username:
2015-01-25 11:08:46,299 [17] INFO - [PremiseWebServiceLibLogger] PremiseBroker::Connect - Creating new session to holly
2015-01-25 11:08:46,307 [17] DEBUG - [PremiseWebServiceLibLogger] clsPremiseconnection::Constructor - Subscribing to connection events
2015-01-25 11:08:46,309 [17] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::Constructor - Attempting to connect to Premise Server: holly
2015-01-25 11:08:46,310 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 1
2015-01-25 11:08:46,311 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Connecting event happened
2015-01-25 11:08:46,321 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 2
2015-01-25 11:08:46,321 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Failed to connect event happened
2015-01-25 11:08:46,323 [17] ERROR - [PremiseWebServiceLibLogger] clsPremiseconnection::Constructor - Unable to connect to Premise Server: holly
2015-01-25 11:08:48,335 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:08:50,344 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:08:52,360 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:08:54,372 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:08:56,384 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:08:58,396 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:00,408 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:01,329 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseConnection::ReconnectTimerEventProcessor - Reconnect timer triggered
2015-01-25 11:09:01,329 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::Reconnect - Attempting to reconnect to Premise Server: holly
2015-01-25 11:09:01,330 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 1
2015-01-25 11:09:01,330 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Connecting event happened
2015-01-25 11:09:01,341 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 2
2015-01-25 11:09:01,341 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Failed to connect event happened
2015-01-25 11:09:01,425 [19] INFO - [PremiseWebServiceLibLogger] PremiseBroker::Connect called for holly with Username:
2015-01-25 11:09:01,425 [19] INFO - [PremiseWebServiceLibLogger] Session already exists. Reutilizing session with holly
2015-01-25 11:09:01,426 [19] DEBUG - [PremiseWebServiceLibLogger] Function GetPremiseConnection called
2015-01-25 11:09:01,427 [19] ERROR - [PremiseWebServiceLibLogger] PremiseBroker::Connect - Failed to retrieve sys://Home object: Object reference not set to an instance of an object.
2015-01-25 11:09:02,421 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:04,433 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:06,446 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:07,678 [19] INFO - [PremiseWebServiceLibLogger] PremiseBroker::Connect called for holly with Username:
2015-01-25 11:09:07,678 [19] INFO - [PremiseWebServiceLibLogger] Session already exists. Reutilizing session with holly
2015-01-25 11:09:07,678 [19] DEBUG - [PremiseWebServiceLibLogger] Function GetPremiseConnection called
2015-01-25 11:09:07,679 [19] ERROR - [PremiseWebServiceLibLogger] PremiseBroker::Connect - Failed to retrieve sys://Home object: Object reference not set to an instance of an object.
2015-01-25 11:09:08,458 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:10,470 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:12,482 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:14,494 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:16,335 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseConnection::ReconnectTimerEventProcessor - Reconnect timer triggered
2015-01-25 11:09:16,335 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::Reconnect - Attempting to reconnect to Premise Server: holly
2015-01-25 11:09:16,335 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 1
2015-01-25 11:09:16,335 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Connecting event happened
2015-01-25 11:09:16,349 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 2
2015-01-25 11:09:16,349 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Failed to connect event happened
2015-01-25 11:09:16,349 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseConnection::ReconnectTimerEventProcessor - Reconnect timer triggered
2015-01-25 11:09:16,349 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::Reconnect - Attempting to reconnect to Premise Server: holly
2015-01-25 11:09:16,350 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 1
2015-01-25 11:09:16,350 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Connecting event happened
2015-01-25 11:09:16,360 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 2
2015-01-25 11:09:16,360 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Failed to connect event happened
2015-01-25 11:09:16,506 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:18,518 [20] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:20,534 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:22,544 [20] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:24,556 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:26,568 [20] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:28,583 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:30,595 [20] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:31,360 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseConnection::ReconnectTimerEventProcessor - Reconnect timer triggered
2015-01-25 11:09:31,360 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::Reconnect - Attempting to reconnect to Premise Server: holly
2015-01-25 11:09:31,360 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 1
2015-01-25 11:09:31,360 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Connecting event happened
2015-01-25 11:09:31,371 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 2
2015-01-25 11:09:31,371 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Failed to connect event happened
2015-01-25 11:09:31,371 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseConnection::ReconnectTimerEventProcessor - Reconnect timer triggered
2015-01-25 11:09:31,371 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::Reconnect - Attempting to reconnect to Premise Server: holly
2015-01-25 11:09:31,371 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 1
2015-01-25 11:09:31,371 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Connecting event happened
2015-01-25 11:09:31,381 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 2
2015-01-25 11:09:31,381 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Failed to connect event happened
2015-01-25 11:09:31,382 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseConnection::ReconnectTimerEventProcessor - Reconnect timer triggered
2015-01-25 11:09:31,382 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::Reconnect - Attempting to reconnect to Premise Server: holly
2015-01-25 11:09:31,382 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 1
2015-01-25 11:09:31,382 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Connecting event happened
2015-01-25 11:09:31,391 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 2
2015-01-25 11:09:31,391 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Failed to connect event happened
2015-01-25 11:09:31,391 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseConnection::ReconnectTimerEventProcessor - Reconnect timer triggered
2015-01-25 11:09:31,392 [4] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::Reconnect - Attempting to reconnect to Premise Server: holly
2015-01-25 11:09:31,392 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 1
2015-01-25 11:09:31,392 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Connecting event happened
2015-01-25 11:09:31,401 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Premise connection state changed= 2
2015-01-25 11:09:31,401 [18] INFO - [PremiseWebServiceLibLogger] clsPremiseconnection::onChangeConnectionState - Failed to connect event happened
2015-01-25 11:09:32,605 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:34,620 [20] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:36,632 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:38,644 [20] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:40,657 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:42,669 [20] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
2015-01-25 11:09:44,681 [4] ERROR - [PremiseWebServiceLibLogger] clsPremiseConnection::HearbeatTimerProcessor - Premise server not responding to heartbeat-Catchall Object reference not set to an instance of an object.
