You need to consider the AWG of the ground cable and path. The key in the referenced unit is the ohm rating that is given (actually pretty much a quote from the NEC) that would reference the ground rod installed itself.
The unit you posted would protect the connected equipment assuming a common building system ground plane and the appropriate resistance. It's not going to protect from a surge coming in on system cabling, just a surge coming in on the HV lines....think about the distance involved and how long it'll take for the unit to shunt the surge in relation to any field connected component and cabling length to that component.
