I didn't go with Centralite because I believe that their system is up to 48 loads. I have 150ish.
I went with a Centralite Elegance system with 96 high voltage loads and 16 low voltage. The max limit is 384. I installed the system myself.
Brian
66 Blocks are designed for 22 to 26 AWG solid. I am using 22/4 for the contacts, motion sensors, etc. I haven't pulled wire yet, but will let you know how it works.
All lighting control wire is now pulled. 70 locations pulled to 4 different enclosures. One 50" Channel Vision (enclosure on the right) and three other 14" enclosures. The plan is to terminate the C-bus using bridged telephone modules from Channel vision.
For my upcoming redesign I am actually looking a terminal blocks. I made a contact at Ehx last year that has ones with internal jumpers. I thing alot of people stat away from them because of price and you have to buy pretty large quantities (at least 50 or 100 a pop).
About 1/2 way through pulling the cable runs, which started from longest to shortest. Wow, what a job, so far about 12 man days.
In addition to the great writeups on CocoonTech, I learn a few additional things:
1. Covering the metal in the trusses was VITAL, so that the wire would not snag, bind up, or get nicked. I used extra PVC piping nailed in place which worked great (see picture bridging1).
2. Pull strings suck. They wrap around in the cable, then the next pull is really hard due to the wrapping. We quickly learned that after a pull was done, use a fish tape to lay down the next pull ON TOP of the previous pull. We used a 150' rope from Lowes, and were carefull not to pull too hard.
3. For the corner, I installed a 3" PVC conduit with the it's back cut out. After each pull, the wires are pulled out the back of the corner, so that the conduit is "clean" for the next pull going around the corner. I guess that I could have used pulleys, but for some pulls, we are 24+ wires (see picture corner1).
4. For the spools, I created a jig buy drilling holes in some 2x4's and then putting conduit or rebar (what ever was laying around) for the axle. This works OK, but it's much better to put some nails in the face of the 2x4 so that the axle can be popped out for replacing spools (see picture spools and boxes1)
5. Beldens station wire packing in plastic sucks. It's so coiled that it really wants to wrap around it's nearest neighbor, making it hard to pull just one.
It's gonna be a great feeling when all this is done!
Will post the pictures when some more space can be allocated on the CT server
