Enjoy the pictures
Thanks for the nice compliments.
CORT,
Yes, the Home Automation room is going to be below the curve staircase. The house is like a square donut with a courtyard in the middle, so the stairwell was centrally located near on corner. If I were to do it over again, I would have been doing prep work such as selecting and marking where the cable would run while the electricians were working (aka, when it was warmer!)
Only half the runs are in, so I'll be sure to update the pictures once all the wiring is in place.
Yeah, 1/2 way as far as pulls go but since the long pulls were done first, more than half way by cable distance. What a job this was/is. I can't wait to do the "I'm done" posting that bezelrob just did
Heh..not to disappoint you too much, but I was about 80% done with the pulls after the first week. The remaining 20% took up the next 2 or so weeks (though they weren't full weeks like the first had been). You end up with all this little stuff that you know needs doing.
I highly recommend you start or keep a list of things that you know need doing, especially as you think of them, or you will for sure forget something. When we first started, I didn't have a list because the wire was items 1 - 100 on the list....but as we kicked out pulling wire, the little details started becoming more important (conduit to here or there, mudrings installed, window wired sensors installed, attic cable support, etc).
I also thoroughy recommend pics and/or video....we kinda screwed it in this, because we didn't take pics until after we had installed the sound dampening insulation, and I didn't feel like ripping it out. You can still see what enters a stud cavity from the top, but it's still not as complete as I'd have liked.
I'm glad to announce that I finished pulling the last runs yesterday.
DJK,
The project looks like a pile of fun. Out of curiousity why don't I see anyone use dim rail termination blocks that are used in the Commercial automation industry. I have used some of the Euroblocks, they are cheap but don't have flexibility in terms of jumpers and grounding. During the design and implementation of a commercial control system last fall, i gained and great deal of respect for the easy of terminating and control wiring on the DIN rails. These were used mostly for terminating 18awg wires however but keep the following terminator modules in mind on your next project. They could come in handy for certain things, also i really like the ability to have different colors.
Rated for 26-12 awg @ 600v depending on the item.
3 circuit block Automation Direct - triple level termination block
single level termination block - Automation direct - termination blocks pdf
