I've been away from the forums for a bit... Holidays, vacation, other projects, job search efforts, etc.....
I'm finally getting around to setting up monitoring of my Elk M1G system. I'm most likely going with AlarmRelay after reading the chatter on these forums.
Today I was setting up and testing the telephone line configuration. For testing, I was trying to use the voice response remote interface. I turned on internal/external control in the Global area in RP. Access from a telephone INSIDE the house works great.
My question comes when I attempt to use the remote control via an inbound telephone call. I'm looking at 'number of rings' and the 'call/hangup/call again' feature. And all of this in conjunction with a telephone answering machine (machine in the house, NOT a telco service).
If I turn OFF the answering machine, the panel DOES answer on the configured number of rings. Or with the answering machine on the number of rings set low to have the M1G pickup BEFORE the machine does.
BUT, I can't get the 'call/hangup/call again' feature working reliably. AND I can't get the M1G to recognize the '***' command if/when the call goes to the answering machine.
I don't want to debate the use of the telephone remote control feature, as I'm NOT sure that I'm going to use the EXTERNAL mode, but I wonder why I can't make it work.
I KNOW that the external remote feature has little to do with monitoring, but I was using for testing the telephone interface....
Do folks use the feature? Does it work for others?
I have f/w 5.2.10 in the panel.
Thanks.
Thanks.
