I have installed a system with the components listed in the title of this topic. For the key fob I have successfully set Standard Mode and configured the control to use Loop 3. This allows the use of the lock and unlock buttons to arm and disarm, respectively, the system to Away. Looking at the instructions for this key fob, it appears that things can be programmed at least for a Honeywell or Ademco system to perform many functions more than merely arming and disarming. Unfortunately, I have not been able to find any documentation on how to have more than the simple arming and disarming for an Elk system.
So, my question is how might I be able to do this for the Elk system. For example, what if I wanted to arm the system to Stay instead of Away? Or what if I wanted the key fob to function as a panic button? I think the key fobs that can be used with the GE wireless expansion will allow you to arm, disarm, and trigger other functions.
Any assistance provided will be greatly appreciated.
