ELK-M1XRF2H V2 Help
lurlette
I have the ELK-M1DBH connected to the data bus on the M1 gold board and a elk-M1KPNAV connected to the M1DBH via a RJ 45 jack, is it okay to connect the M1XRF2H V3 to the M1DBH or it’s better connected directly to the data bus on the m1 board?, thanks in advance for all the help.
You connect it either way. It doesn't make any difference from an operational point of view, though it will change how things have to be terminated. The data bus can only have at most two branches. The DBH forms one of them. If you connect the XRF2H to the M1, that will be the second branch. So you would install a termination jumper on the XRF2H and remove the jumper from the M1.
