Just hooked up my main floor garage doors to the M1XOVR output relays and noticed that after using the elk to turn those outputs on and then off, that the clocks on the openers were flashing 12:00. so i watched the openers as I triggered the outputs to close the doors and I can see the screen go off and remain off for the duration of the output being switched "on". then the screen comes back on with an error code for a moment then goes back to normal. I've got them hooked up the same way that the manual shows an example. Could it be possible that I hooked the wires up in reverse? I assumed that the output was just completing a loop to tell the opener to close the door but I don't really know.
Edit: tried reversing the wires to the N/O and com terminals but same results.
I also have 1 of the openers hooked up to output 3 on the main m1 board and it has the same behavior.
