mikefamig said:What is the advantage of using the water alarm rule instead of just checking to see if the zone is violated? And if the water alarm rule beeps the keypad as you say then it is firing and not the problem. I don't think that I am understanding this correctly.
Mike.
Since he has multiple water sensors, using the "any water alarm" rule allows things to be condensed to a single rule, rather than using multiple rules to check each zone individually.
From @mp333's previous posts, it doesn't matter which form he uses. In both cases, the output doesn't change as a result of the rule.
