Help needed with IR and Vanco HDMI over Cat6 Adapters
lansa
Just finished a project installing 6 TV's, all fed by Uverse boxes that are connected with Vanco HDMI over Single Cat6 adapters. While the picture has been trouble-free, I've been having repeated issues with the the IR transmitters on the Vanco's that control the set-top boxes. Sometimes they just stop working and require the IR cables to be unplugged and plugged back in and then they work fine for a while. This keeps happening on 1 or 2 TV's and is obviously unacceptable. Has anyone has similar issues and know of a fix?
Should not be an issue. You should be able to go 165' at 1080P.
Although the Xantech should work, is there a reason you aren't using the emitters that came with the unit?
If you want to talk to someone that is really good at this stuff, call our office and ask for Brian.
