dadarkjedi
Hello everyone, I’m new to the forums and would like to introduce myself, my name is John, and I live in little Rhode Island, I just recently purchased a new home with an existing security system, and no info came with the system, the house is roughly 16 years old and have very little knowledge when it comes to installing security systems so please be gentile.
I have spent a few weeks reading up the ELK M1gold, and it seem to be the most popular and most referred system on alot of forums, I’m more or less looking to it for security amt, but look forward to doing the home automation shortly after I get it up and running. My only concern really is, I have an old Guardaware system, CU-66 board and the original owners never gave any of the info on the system to the owners we purchased the home from, and I managed to reset (after setting the siren off like 10 times lol) my own pass code to use the system, unfortunately, I can only get the system to work in at-home-mode ( no motion sensors ), when I set the system to away-mode, one of the zone lights on the key pad (zone 1) goes off as if a door or window on that zone were open, normally all the lights are on when all doors and windows are secure, but I have confirmed non are open, but when I set the system to at-home-mode, the zone light goes back on, everything works fine but my motion sensors wont work for obvious reasons being in at-home-mode.
I haven’t been able to find a manual for the system anywhere online or from other alarm dealers so I opted to replace the system and chose to go with the ELK M1G. I would like to use all the hardwired sensors that are in place as far as the door and window sensors, and will be replacing the motion sensors with new hardwired ones and adding a few more, but my only concerns is I’m trying to figure out what is causing my current system not to work in away-mode and what effect that will have on the Elk system, I’m assuming I will be able to just unhook the old system and replace it with the M1gold and wire everything back in to the new system without toooo much trouble on the panel side of things, but does anyone know of a way I can try to test the zone that’s giving me trouble on the old system now, and maybe solve that issue before I tackle the installation of the M1gold, keep inmind I have no manuals or anything for the old one, so if there is a device someone mite know about that I have to purchase that would help me, I would greatly appericiate it, and Thank you in advance for your help and awsome forum.
