Hi
I moved into my new one bedroom apartment recently. I've also been a fan of automation and come from an IT tech background. However, in terms of automation, i’m kind of new. I’ve been doing a lot of reading in order to understand how it works and all, the connectivity…etc.
I live in the United Arab Emirates, thought you should know as somethings won’t work here without power conversion as the voltage here is 220v.
I’m doing this because I enjoy technology. I know, it’s an expense hobby
I want to do the following:
- Control all my equipment via a Harmony remote for now and my iPhone/iPad, and maybe voice in the future (Let's see how Apple plans to introduce home automation they announced this week).
- I want to be able to control it over the Internet as well.
- Create scenes and scenarios (e.g. at 7 a.m., open all my shades/blinds). Maybe also later on do this “When i walk into my home, and send voice command to switch on the project and set the input to be my Plex”.
- Don’t like the clatter and mess of too many cables, so i’m planning to use the least amount of cables, and that’s why i decided to buy few of the products below.
“The Product / IR/RF/RS232 / Description”
Inputs
1.) Intel NUC / IR / (which is a windows OS, with Plex Media Theather), will be used for Plex only.
2.) A Browsing Computer / No IR / (which i mainly use and mostly used system).
3.) ISP STB receiver / IR /
Outputs
4.) Samsung 46’’ TV / IR
5.) Epson 8350 Projector / IR & RS232
Both displays are in the living room, as i like to watch TV while i browse on the projector.
- What I purchased and waiting for it to be delivered this week:
-- Philips Hue (GU10 starter Kit) with 7 additional bulbs, so a total of 10 bulbs and the gateway/hub.
-- iRobot Roomba 880.
-- Quirky spotter (got it to test it, no plan on how I will use it yet).
-- DVDO Matrix6 HDMI switch
-- DVDO Air3 (To connect my project to the DVD Matrix6 wirelessly, as I don’t want to pull a long HDMI cable from projector which is on the opposite side of my rack).
In my "to buy" list:
-- Sonos audio system (will start with Playbar and add subwoofer and additional speakers later). I'm not an audiophile, but I still need a good sound effect. The Sonos will be used for my projector. The DVDO matrix switch has optical audio out which will be connected to the Playbar.
— Motorized blinds (deciding between Somfy or Douglas Hunter at the moment). Somfy is widely available in my region, so I might go for this week. Somfy uses RF.
There is no single way of doing a home automation, and i think many of you will suggest that i shouldn’t have done this and that. I’m open to your feedback, no harm in learning more or understanding how you would have done it.
So now, putting it all together and making it work will be the exciting thing.
First of all, I believe that using an iPhone as a remote won’t be practical at all, a physical remote must always be there. That’s why, I want to be able to use my iPhone and my harmony remote, and a later stage, I will add voice capability.
After hours of reading, I’m learning how this whole thing works. You guys are more experienced than me, so your assistance is greatly appreciated.
There must be a central controller that connects and communicates with all the devices. Since not all the devices have common protocols (IR, RF, RS232), I must buy components that converts the commands sent.
What controller do you recommend? Same goes to the converting of the commands devices, which ones? Am I missing some other things that I might need to achieve my goals of this project?
Am i on the right track? Correct me If I’m wrong or missing anything.
Thanks all.
Inputs
Outputs
Thanks all.
