apostolakisl
1) CS calls your installations back on a pots line, the same pots line that the panel uses to call out? This must be one of your many $20M installations. To paraphrase a nearly former president, 1980 called and wants their alarm panel CS back.
2) CS does call my cell phone, if no response, they call wife, if no response they dispatch. Seems like a really good way to do residential, probably the way most people do it. It works real well. Dispatch occurs within 2 minutes of alarm or less. My CS calls me within 30 seconds. If I don't answer, it adds another 30 seconds to call my wife.
3) If no one is there to manually reset, then I guess you have persisting alarm/trouble codes until someone shows up. Doesn't sound like a big issue to me, since after all, you did have a fire alarm go off and either 1-you have a fire, or 2-you have a malfunction. Either way, someone needs to show up.
4) Manual reset kills power to smokes, smokes shut off, power restores, smokes turn back on to normal mode (assuming normal conditions now exist) and trouble condition resolves.
5) arm/disarm panel and trouble warning clears
6) $20 million houses?
