potts.mike
Storage spaces is the drive pooling feature in windows 8 and above. As far as VM's 1 small debian machine for sure and then 2 or 3 windows 7 VMs. The VMs, for now, are really more a learning exercise than anything.
drvnbysound said:My initial plan was to run BlueIris an SageTV on VMs on the HT i7 build. However, as I build it out I'm fighting with myself about how I want to go about distributing the video from BI. I need to be able to get camera views on my MBR and Living Room TV's and would prefer if they were the full screen feeds of the cameras; that's a bit harder to do from a VM vs leaving BI on the host OS and using the HDMI out. I'm soon to come to a decision point on it and am leaning toward having BI on the host, but still running STV as a VM (mainly for management reasons) that shouldn't effect BI any. I only use the STV extenders with STV, so only need network connection to access the video there...
batwater said:I have to rebuild my Blue Iris server and am pondering the same thing. My initial thought is that I put BI on a VM. I am working along the lines of a 2nd video card with HDMI out that is dedicated to Blue Iris and then feeding that into a Matrix switch. Or maybe an android device hooked up via HDMI running the BI client or IP Cam Viewer which can be controlled via Tasker. If I go the tasker route I should be able to trigger from BI host (event) to the android client to pull up whatever camera I need to.
