I'm sure I'm approaching the limit of what can be run, but i'll bet this is a whole lim f(x)= ∞ . Perhaps marginal incremental value will set in, but I haven't yet reached that point...
pete_c said:Don't run any cables and try using wireless widgets configuring whatever events you want.
See if it fits in your home automated environment.
Here have turned down the follow me lighting stuff due to WAF. (maybe age / not liking the house to make automated decisions relating to lighting?)
Not to mention the hassle of getting the ladder out to change batteries. I always do hard-wired unless absolutely necessary (like door locks for example)IVB said:Don't run any cables and try using wireless widgets configuring whatever events you want.
Well, the ROI is tough for wireless, sensors are a lot more. Wired motions are $20 (and consistent), water/etc are almost always even less. The wireless stuff typically starts at $50 and could be more.
IVB said:Well, the ROI is tough for wireless, sensors are a lot more. Wired motions are $20 (and consistent), water/etc are almost always even less. The wireless stuff typically starts at $50 and could be more.
drvnbysound said:True. Here is a Honeywell pet-immune PIR for $45. So apples to apples, yes the wireless ones are always more. But if you already have the wireless receiver it's a different comparison, because that wired sensor isn't just $20 - it's $20 + the cost of wire (sure, cheap) and the time to run it. At that point, $45 for a wireless sensor starts to become pretty appealing. Especially if you start talking about the impacts to insulation and other factors.
And sure, you do run into the battery "issue" but I've seen wireless sensors last 3-5 years (or more).
Just more factors to consider...
http://www.amazon.com/Insteon-Wireless-Motion-Sensor-Retail/dp/B00LLQ0XQS/ref=sr_1_2?s=security-surveillance&ie=UTF8&qid=1441240078&sr=1-2&keywords=Insteon&pebp=1441240106179&perid=1BKG6SYMJPDEHGXXX7PY
DELInstallations said:For insulation, you could, albeit more expensive, assuming you have a full vapor barrier, get encapsulated batts and then move them as you need to and put them back. I also remember one of the big boxes selling denim or a no-itch fiberglas product. Can't remember what it is, I'm sure I have a sample piece somewhere here.
