... apparently my method isnt an "approved" action by all, but fortunately it worked out great for me... no wires were missing or damaged
That said, I didnt mention anything about my keypads, but I did them similar to my in-wall speakers. I simply used some 1" electrical staples to keep the 22/4 from extending beyond the stud bay (and possibly pinched between the stud and drywall) and ran the wire about 2' longer than where I planned to place the keypad. Once the drywall was up, I cut my double gang hole where I wanted to place the keypad, reached my hand inside the wall, and pulled out the wire.
For me personally, I was doing all the wiring to a "spec home" that the majority of home owners never get to do, so I wanted to make the LEAST amount of work for the drywall guys as possible. This is the biggest reason I left all my wiring hidden (speakers, keypads, etc.) where I knew I would be able to easily access the wire from the hole that was going to be cut in the drywall anyway. As mentioned in my previous post, for my window, door, and motion sensors I simply drilled through the studs and routed the wires to exactly where I wanted them (inside the window and door casings) and left the wire exposed for the drywall guys to see. They cut "V" notches into the drywall that pressed against the windows, and mudded the gap that was remaining. The guys who did the finish work on the trim and door casings drilled holes through the door casings and left the wire for me to finish up.
Unfortunately, I didnt get any pictures of the wiring job as I left it, prior to drywall. I had a total of 2 days (Sat and Sun) to do all the wiring in my home, before the drywall guys started on Monday. But this is one of the finished pictures that I have taken since:
