So effectively your bypassing the impedance matching function of the speaker switch? You can't just remove or add speakers connected to one output without dealing with the impedance being maintained between 4-16 Ohms (in most cases - some amps have a tighter requirement). Not doing so can damage the amplifier.
Good luck and watch for smoke.
I don' think so. I did the following in the picture - placing 12 relays between the speakers and the selector.
The speaker selector itself is unpowered, so I believe it only "sees" a speaker when there is current going through the speakers, despite the actual position of the push button switch. If this is true, then my relays should just replace the function of the push buttons.
If the relays are in the on position, I complete the circuit through the speaker selector along with impedance matching function. If the relays are in the off position, no current can pass through it because the circuit is broken. So the speaker selector should only "see" the completed circuits, the ones where the relay are on, and perform impedance matching through those.
How can I screw up the resistence levels with this setup? My understanding is that if I accidentally hooked up the speakers in paralle then yes I can drop the resitence, and the more speakers I hooked up in parallel the lower the resitence can drop and blow equipment along the chain. But if the relay switches are open, there'd be no complete circuit, and no chance to accidentally create a parallel circuit?
I looked into the hacs one, but like I said I am a newbie, and getting that unit to work looks like a very daunting task!
