BraveSirRobbin
Moderator
I had this problem when I switched the Elk using the mod for pre-amp output. Probably not applicable in this case though. I'm not sure how you would get rid of that pop when using line level. Capacitor perhaps?
I am not sure I understand exactly where the humm is comming from. You say it is when the relays are "off". So it will humm in the NC position regardless of whether you have music or the Elk plugged into the NC contact? Or, does the humm always follow the Elk?
My expectation is that the humm is comming from the Elk speaker output turned to a line output. Try just plugging the Elk line-out directly into your amp and see if there is a humm. If there is, then you know it isn't the relay. Also, see if there is a humm with the amp connected to the relay's common side, but with the NC and NO connections empty. If you have a humm now, it must be some inductance in the relay.
As far as the delay, I assume it is because the relay isn't switching over prior to the words being output. I really don't think it is the capacitor, but I suppose you could try removing it and see. The easiest way to know if the relay is switching over late is to (like above) plug the Elk line-out directly into your amp and see if you still lose the first few words.
In summary, plug the Elk line-out directly into the amp. If the humm is gone and the loss of the first few words is fixed, then the relay is your problem.
