I have 1710 sq. ft. main plus basement, slightly less. Water heater is at the end of the "L" next to garage to get venting. The long runs are a bit of a mistake for hot water travel. Coupled with everything water-saver it takes about 60-90 seconds to get hot water to the kitchen tap. Dishwasher gets hot water quick as there is no water-saver restrictions. I put in a manifold for both hot and cold but the hot is a mistake. By the time the hot water hits it, heats it up, and runs down the long PEX it takes forever. The manifold will come out with a tree structured feed maybe this winter. Many have installed circ pumps for "instant" hot water feed constantly in the main pipe. There is a scheme to make that work using a small tank, somebody posted on a forum somewhere.
My old tankless (Rinnai) took 0.6 gpm to turn it on and off. The newer unit (Rinnai) takes 0.6 gpm to turn on and 0.4 gpm to turn off. That doesn't sound like much flow. I measured about face washing flow = half on from a water-saver faucet. But... you probably have waters mixed less than 50% hot when actually using. The tankless only sees that portion.
My units were both 15,000 to 180,000 BTU. Yeah go for the biggest and bestest capacity you can get! Wrong!
The bottom end is more important to wash your face with low flow than having three showers at once! Watch the gpm rating as it is based on a certain temperature rise and if you are on a well your water comes in at about 50F and the flows are way down for bragged ones. Get to know the BTU formula. It's pretty easy (in USA terms) and I think Wikipedia has the answers there.
Then there is the venting. The Rinnai unit takes double wall concentric pipe. A friggin' elbow in Canuckistan is almost $100! and that is from the plumbing wholesalers as a contractor. Yeah I cross border shopped for those at about 25% of that price.
The Rheem unit sold at homedepot.ca takes two cheap white PVC ?? pipes tht are much easier to install. My neighbour installed one of those in a very smallhouse this year and he is happy so far. He is running hydronic baseboard so his needs are different than mine with just on or off.
Remember the price of the tankless may not be the major expense in the thing depending on your venting. I had to destroy my first unit removing it 'cause the snow fell six feet over the outlet one year. The aluminum inner pipe was welded together from the gas fumes corroding the aluminum. It's the same old gottcha'. It the price of the accessories that kills ya'.
I hope your LPG is cheaper than your electrical energy. Our's runs about the same so no break would happen there and most elect. people in the rural are running elect. heat pump t get consumption down.
