The first thing I do is consider how I will run wire in the future in the house after the walls are closed up. So create paths with conduit back to your central closed to every possible room and control location, and make sure you have enough empty conduit capacity for the future, bends will take 1/3 to 1/2 of conduits capacity, straight you can squeeze more in it. And install pull strings in them. Solid conduit is better than the flexible for capacity.
If you can't run conduit, then run extra Cat5 to all rooms with mechanicals, electrical panels, DMARCs (phone box, cable box, dish locations, antenna locations, garage, sprinkler controller, outdoor lighting controller/transformer) etc. And I would run Cat5 to your camera locations as well so you can do ethernet based cameras in the future if you choose. Anywhere you are going to have equipment or control panels of any kind run Cat5 if you can't run conduit.
For example, when I moved into my house the first thing I did was run conduit, between my closet and attic, between my split attics, from my closet to all unfinished areas, etc. Now pulling new wire is a lot simpler.
Along with LV, consider running HV conduit also from your electrical panel location to connect areas. I am also a fan of having multiple electrical panels/sub panels in a house. For example, I would rather have a subpanel (with extra capacity) in my HVAC/mechanical room and garage, than straight runs. While this will add expense now, you can roll it into your mortgage and it will save a LOT of time and expense later.
I would also make sure the electrician:
- installs the deep and adjustable electrical boxes. Easier to work in, and you can adjust depth which is safer and more presentable for different wall covering depths.
- use WAGO lever nuts instead of twist nuts if the inspector will allow them. (This prevents wear on the wires, less likely to break if you replace something)
- Tell them no shared neutrals (this is allowed by code but shouldn't be IMHO, it creates a risk of electrocution to working in boxes in the futue).
- No more than one circuit in a jbox unless there are special circumstances they clear with you first. I have seen crazy things like my furnace circuit running through one of my smoke detector jboxes just as a junction to save wire. That made it very hard to determine what circuits to turn off when working in that box. I am willing to pay an extra $20 for wire to prevent something stupid like that.
- Must use insulated staples. I guarantee you there are staples piercing wires in every house built. Insulated staples make this a lot less likely. I know of one house that burned down because of this 30 years after it was built.
- Get a wiring plan or make one yourself before the walls go up. Record exactly which circuit(s) run through each box. Determine what is the estimated load on each circuit (based on number of lights and outlets). Record the wire guage and breaker for each circuit. This will help keep the electricians honest and the inspector will love this as well. But most importantly it will make any electrical work safer and easier in the future.
- Take lots of pictures and/or video before the walls go up.
- Also, if your attic is accessible and you intend to store stuff there/plan on putting flooring down, make them run the wires high or through joists, not over. Just tell them ahead of time you plan on putting flooring down in the future.
