I have an interesting problem...
Here is the setup for this particular trio:
- SwitchLinc V2 #1 which controls the load for the main dining room light.
- SwitchLinc V2 #2 on the other side of the room which controls no load.
- LampLinc V2 on an outlet in the room with a lamp connected.
Linking layout:
The above works properly but...
When I originally linked the SwitchLinc V2 #1 to the LampLinc V2, I set a ramp rate (which works properly). Additionally, when I turn on #1, #2 ramps up properly.
However, I cannot for the life of me get the LampLinc V2 to ramp up from #2. Doing it no differently than the other 6 switches I have already installed, it seems to accept the programming and then when tested, instantly turns on and off.
I know that the software forthcoming from SmartHome to perform the linking will likely resolve this down the road, but I would like to solve it now.
Jim
Linking layout:
Code:
SwitchLinc V2 #1 ----> LampLinc V2
SwitchLinc V2 #2 ----> LampLinc V2
SwitchLinc V2 #1 ----> SwitchLinc V2 #2
Notice that SwitchLinc V2 #1 controls #2 but not the other
way around. This is on purpose. The main light switch controls
both the main dining room light and the stand lamp on the
other side of the room. However, if you want just the lamp
in the sitting area, you use the other switch.
Jim
