Desert_AIP
In order to track changes you HAVE to set the lighting mode to HLC and use HAIs room, unit, link allocation scheme.
Since you are using non HAI switches, you have to manually configure the switches with UPStart and also manually enter them into the Omni with PCAccess.
Those pdfs detail the room, unit and link allocation scheme.
Now the A, B, C, D links have default behaviors of room to 20, 40, 60 and 80%. But you can make the switches in the room do anything you want. And you don't have to have all the switches respond to all 4 links.
Same goes with the ON and OFF links, but it's a good idea to keep those default behaviors for All On and All Off.
As you'll find in the other threads, the first unit in a room. Is reserved for a room controller, but have to name the first unit in a room, even if you don't have a room controller. The other 7 units in a room can be anything,
