So it's hard to explain with words. The existing meter is round. The needle spins within it like a speedometer. If you remove the meter from the tank, underneath you'll find it's just flat brass. ........
Nice explanation.....and nice idea.
I think I got it except for the flat brass part.....
On the logic to separate the low level from the high level.......I have one idea for you to consider. The logic would have to make some assumptions, based on recent past readings, so it would also have to keep a history of readings. But you could do this:
1. If the level is moving slowly, then it is being consumed and is decreasing, moving toward the low level end.
2. If the level is moving fast, the tank is being refilled, and the reading is moving toward the hi level end.
These are the only two cases. It seems like it should work.
Thanks for posting. This is an interesting idea.
By the way.....I have much industrial experience in installing electrical equipment in electrically classified areas. For a tank such as this, according to NFPA 497, Figure 5.9.2b, a 15' diameter spherically shaped Division 2 volume would defined around the tank refill connector and any vents such as a relief valve. There is no Division 1 volume defined. With Division 2, there are other methods of meeting the area classification besides using intrinsic safety methods- such as being hermetically sealed.
