I have experience with Insteon, having implemented it shortly after if came out many years ago in a former home. I had dealt with the issues with the earlier switches, but it had seemed to get better with later batches and Smarthome had replaced the bad ones. I have a box of controlled switches and dimmers and plug in modules, and an ISY controller, aside from previous experience using this and setting this up with an Elk. It had seemed to me that reliability was better in the later units. I also learned that extended warranties were a good investment.
I'm in a new home and was thinking of going the Insteon route again, but saw references to RadioRA2 being rock solid and somewhat DIY friendly (I had anticipated doing it myself originally). I already see cases where I would like to link switches to clean up how the switches are laid out (via linking and keypads using the Insteon analogy). This would essentiall abandon some of my existing hardware and experience but would ensure this was professional grade (albeit at a premium).
While this question may border on a religious one in some cases, is RadioRA2 something that should be given special attention and is it worth the premium? I would probably build this out over time. Are there any special advantages I would get with this approach? I did see the shade control which seemed interesting but it seems I could do this separate from lighting control if I wished as well (not sure if/what I would do there, but it is an area of interest).
I have not done the specific math but I would likely have about 50 loads (for lighting).
I am not quite clear how DIY friendly these are as well, although I did see some on Amazon and it looked like these may be dealer items on AutomatedOutlet (for example) but I have not reached out to them either. It sounded like I'd need to get a copy of the software as well.
Thanks.
Thanks.
