We use (and appreciate) the voice chime on all of our entry doors and windows (Elk M1 system with speakers behind the keypads). But when we have a party or people are going in and out to the deck, it gets crazy annozing.
I would like to limit the number of times that the chime on any given door can be activated. For example, limit the door chime on the front door to once in any five minute period.
What do people recommend for accomplishing this? If at all possible, I would like to retain the ability to turn off chimes completely using the chime button on the keypad.
My initial inclination would be to disable the chime and then create a rule as follows:
If (front door is open) and (counter1 > 300 seconds)
play voice announcement "Front door is open"
reset counter1
But then I lose the ability to disable chimes using the chime button. As far as I know, there's no way to check if chimes are enabled using Rules, is that correct?
reset counter1
