42etus
<p>We had a local power outage and when the power came back up the Elk wasn't behaving normally. I opened RP2 and found that the IP address of the XEP had some how changed from 192.168.1.60 to 192.168.3.64 . Now I'm not able to login to the XEP to change it back to the correct IP address.</p>
<p>I have rebooted both the M1 and the XEP several times, but that didn't help. I have connected my laptop directly to the XEP with a cat 5 patch cord, but was still not able to connect (using the 192.168.3.64 address). I'm at a loss here as to how to connect to the XEP and set the IP back to what it should be. Suggestions are welcome.</p>
EDIT:
OK, I RTFM and followed the procedure on pg 25, set the XEP to DHCP and used the new assigned IP address to connect. Then I simply changed the IP back to what it was previously and all is good. Strange though; the MAC address that is show when I do a "FIND" isn't the MAC address on the XEP label. What's up with that?</p>
EDIT:
