beelzerob
So, the 2 things I'd like most to monitor (that I'm not already) are my water heater and my well pump. Both are 220v, of course.
So I need to feed 1 hot wire through this switch, right? Probably with the water heater, it will easily exceed 1 amp when in use, so I won't need to add any loops. The pump is variable speed, though, so a couple loops through that would probably be a good idea.
But is there any safety issues involved in disconnecting the wire from either the water heater or circuit breaker panel and running through this thing and then reconnecting it? (assuming I turned the power off, of course). It's not one of those "it must be torqued to the exact amount" sort of connections is it?
