I just moved into a new house and I'm having two similar problems and I think I have a very inexpensive way to solve them, but I was looking for a bit of advice. The house I bought is a three story townhouse with living space on the first and second floors on one heat pump and the bedrooms on the third floor on a second heat pump. What I've discovered, after living here for a few weeks, is that two of the bedrooms face the east, so in the morning when the sun rises the temperature in those rooms also rises and those rooms can be several degrees warmer than the rest of the bedrooms. Also, along the same lines, during the day the second floor tends to get somewhat warmer than the first floor.
Now that I've automated the thermostats (I installed two TZ16's) I was wondering if I could solve my problems either by having HomeSeer run the just the fan without turning on the AC for a few minutes every hour (given the current outside temperatures the AC can be off for several hours, especially durning the night). Or, maybe even better, get something to monitor the temps in the rooms where I'm having problems and use HomeSeer to compare those temps to the temp at the thermostat, and if they're far enough off, have HomeSeer turn the fan on until they even out.
Do you guys think that might help? I don't really want to go through the labor or expense to install a zoned system and I'm thinking that just running the fan alone will help distribute the air and even out the temps.
Also, along a completely different line, the thermostats I replaced had an interesting feature. After an AC call had been satisfied they would shut off the compressor, but continue to run the fan for a few minutes. The theory, from what I've been told, is that the evaporator coils are still cold immediately after the compressor shuts off, so you may as well run the fan a bit longer to make sure you get as much cooling as possible for the energy spent to run the compressor. This makes sense to me, and I've set up a couple of rules in HomeSeer to emulate this behavior with my new thermostats, but I wasn't sure how long to run the fans after the compressor is shut off. Unfortunately I didn't pay close enough attention to see how long the fan ran after an AC call with my old thermostats and I can't seem to find much info online about it. Does anyone have any suggestions about this?
Thanks much,
Brett
Thanks much,
Brett
