wkearney99
There aren't going to be any LEDs or dimmers that will drop to 1%. I'd argue there's absolutely no reason to "need" that low a dimming percentage. That and previous analog dimmers likely never got that low either. Yes, old-school rheostat-based analog dimmers with incandescent filament bulbs may well have been possible to get a candle-wick bare glimmer. But at the cost of serious overheating risks at the dimmer and ridiculously shortened bulb life.
That and if you needed to dim things that much then you'd likely have too many lighting elements in the first place.
This isn't to defend what the Lutron dimmers provide. I'm no fanboy when it comes to products vs consumer needs. But I am a realist when it comes to what's actually possible with modern tech.
One nice feature of the Lutron RA2 dimmers is the ability to tune their high/low dim values. This is useful if you run into situations where the dimmer's handling at very low dim levels causes problems with the bulbs. Some CFLs and LED drivers will start erratically flashing if the power is dropped below a certain threshold. One solution is to raise the floor value of the dimmer to avoid that range. The customer can use the side dimmer to adjust things manually and the switch will avoid dropping below that preset value. The customer feels things are working properly, never the wiser that their bulb choices weren't ideal.
