Tried a copy and past of 1150 lines of firmware notes and forum got stuck...so here is a shorter version of release notes:
PC Access Version 3.17.0.838 (17/January/2017)
Controller firmware 4.0b released:
- Added support for flash memory module. IMPORTANT: Firmware versions below 4.0 may not be installed in controllers with flash memory modules.
- Improved contact ID reporting compatibility for account codes containing zeroes.
- Improved contact ID reporting compatibility when the checksum value is zero.
- Added support for Omni firmware 4.0.
- OmniTouch 7 firmware version 1.15 (99A00-1/2) released:
- Fixed limitation of four OT7s displaying video preview for 2N door stations
- Added separate volume control for ring volume in settings page
- Review trouble conditions are displayed for Omni
- Fixed wake lock issue
- Enhanced IP Camera Support with built in support for over 250 new camera models.
- Added support Omni Notifier firmware 2.0 that allows E-Mails to be sent using My Leviton Cloud services. This eliminates compatibility issues with some SMTP servers. See Knowledge Base article DOC-4920 for more information:
http://communities.leviton.com/docs/DOC-4920
PC Access Version 3.16.0.808 (20/July/2016)
- Controller firmware 3.16 released:
- Fixed Somfy SDN stop command not working.
- Improved TCP connection establishment for certain TCP clients.
- Added support for HLCK6 UPB keypad.
- Modified to clear any freeze alarm for a non-communicating thermostat.
- Corrected some Italian translation errors.
PC Access Version 3.15.0.803 (17/December/2015)
- Omni Notifier firmware version 1.5 released:
- Improved performance and stability.
- Added button to read and display firmware info on the Notifier setup page.
PC Access Version 3.15.0.799 (15/October/2015)
- Added OmniTouch 7 Kernel Version 1.1 and OmniTouch 7 Firmware Version 1.12 to the update site. See Technical Bulletin TB-18 for instructions on installing these updates.
This upgrade improves connection reliability, video connections and eliminates a soft sound that can be heard when you hold your ear up to the speaker. Furthermore, this upgrade will eliminate the possibility of the touchscreen producing a static noise from the speaker that can be heard from a distance. Note that although the static noise is annoying if it happens, it does not pose safety or functionality issues.
Note: These updates must be applied together in order.
The OmniTouch firmware upgrade file (e.g. OmniTouch_7_Version_1.12_99A00-1_2.ot7f) must be applied first.
Wait for the touchscreen to reboot, then the Kernel upgrade file (OmniTouch_7_Kernel_Ver_1_1_99A00-1_2.ot7f) must be applied.
After the OmniTouch 7 restarts, press the Settings icon on the bottom-right of the OmniTouch 7 menu bar.
Press and hold the Settings icon for 3 seconds.
The firmware version is displayed in the title bar. Verify that the Kernel Version is 1.1 or higher.
- Fixed a few typos and text display issues.
PC Access Version 3.15.0.790 (03/June/2015)
- Added the ability to filter the firmware download list. PC Access 3 supports several models of controller in several languages. This makes the list of available firmware files rather long. Often you may be only interested in a particular language, or model. The filter looks for text matches in the file names so typing "english" in the filter box will only display English controllers. Typing "IIe" will display only Omni IIe controllers, etc.
- Added support for Leviton and Logenex TELEPORT door stations.
PC Access Version 3.15.0.789 (14/May/2015)
- Fixed problem where the download firmware files window was not big enough to display all of the available firmware files.
PC Access Version 3.15.0.788 (13/May/2015)
- Controller firmware 3.15 released:
- Added EN 50131/PD6662 compliant systems.
- Fixed a problem where invalid zones were shown as tripped during entry delay.
- Fixed show camera command not working on OmniTouch 5.7 video touchscreens.
- Added support for Z-Wave door lock auto lock.
- Modified to use message name for subject in Notifier emails for user logged events.
- Added support for the European Security Standard EN50131 controllers.
- Added 3 new controller models that support the EN50131 standard:
- Omni LTe-EU
- Omni IIe-EU
- OmniPro II-EU
PC Access Version 3.14.2.783 (27/March/2015)
- Added support for SIP based intercom between IP Touchscreens, door stations and smart devices to the Extended Setup.
- Fixed update E-Mail Notifier firmware via UDP error.
PC Access Version 3.14.1.760 (07/November/2014)
- Omni Notifier firmware version 1.3 released:
- Improved performance of Omni Notifier firmware update process.
- Improved status reporting during Omni Notifier firmware update process.
My personal OmniPro 2 issues over the last few years...
1 - Network / serial bus would get constipated. The laxative I chose was to install a micro router between the OP2 NIC and the main network. There are notes in the release notes relating to network but nothing specific.
2 - Camera displaying in the Omnitouch 5.7e screens. I made mine work. Later a firmware update fixed much of this except for keeping a 4:3 display of video rather than a wide screen display of video. Another issue was a pop up video screen on the Omnitouch 5.7 legacy screens.
So personally having two issues across many firmware updates is not too bad. I never purchased the Email board or the Android Omnitouch 7 screens here.
