damage
I'm going to try to build a Premise module that will rely on your obi110 script. Is the idea that I would just need Premise to listen to a socket connection pointed to port 514 and the ip address of the Obi110? If it can be made to display the caller id data in telnet, it will work in Premise via the virtual UDS-10 trick described above. Any pointers are welcome
no, you setup a socket on your machine to receive syslog messages from the obi or any other device. you configure the obi with the address & port of your syslog "server".
