dlmorgan999
Last year I helped a friend install an OmniPro II in his second home. He recently wanted to add some basic UPB functionality so I got him the parts he needed, helped him program and test the modules (using UPStart), and sent him on his way to install them (we also connected remotely to the OmniPro II and did the UPB configuration). He hasn't been able to get them working from the OmniPro II (although they work fine from UPStart), and I haven't been able to figure out why (I haven't been able to make it to the location, so I've been diagnosing remotely). Here is his description of the symptoms:
Problem: Omni Pro II not communicating via serial port to PIM, so UPB on/off devices aren’t working.
PIM indicator light is green.
Serial Port on Omni shows no indicator; prior to taking PIM out of Pulse mode, the serial light was solid red.
In Dealer Access PC Setup, first 16 units all have same UPB configuration; when Unit 1 is changed to UPB, the next 15 change too. In Dealer Access PC Status/Control (connected via internet) only the two named units show up, but they don’t respond to commands.
Any suggestions on what might be wrong or things to try?
