My "production" in place Omnistat2 temperature is off and always has been. I can adjust it and if it loses power (on and off a few times in a matter of say 30 minutes) then my offset is lost.
I do recall with the HAI RC-80 a temperature adjustment offset would remain in place after removal of power to the thermostat.
I have tested how off the temperature is with the Omnistat2 using two different thermometers adjacent to the Omnistat2.
Today decided just to attach a remote temperature module instead to compare temps and if the remotely connected temperature sensor is more accurate then will use that one instead for the Omnistat. Long term though I would prefer to attach multiple sensors directly to the thermostat to work with the sensors attached to the OPII. I purchased a few of these a while back.
Unrelated but I also have external and multiple internal temperature / humidity sensors connected to the HAI OPII. I do not have one though installed where the thermostat is at; just a 1-wire sensor there.
Is there a way to calibrate the temperature sensor on the thermostat? Like maybe via a direct serial connection with my PC to it?
