Greetings,
Thanks for contacting us. I received this message from our support team.
The 7761-CM is an IP67 rated outdoor WiFi Access Point with an integrated DOCSIS 3.0 cable modem. It is intended to be deployed outdoors on aerial cable plant, in a cabe pedestal or vault. In order to perform adequately in those conditions the integrated cable modem was designed with an extended temperature range, as you note below. The integrated cable modem is not available separate from the 7761-CM. We do not offer an extended temperature range cable modem a separate unit.
Your cable operator should be able to provide you with a list of approved devices for their network. If they have any approved devices that support an extended temperature range, they should be on that list; perhaps they can point one out to you.
