I noticed that also. I wonder if that was intentional. I also noticed that recently they have removed the serial number required, so now the software is open to use.SierraTech said:
I noticed the ICONS are larger in menus as well. Hopefully they solved other PCA crashing issues!
Yet another new update! The icon sizes are fixed. Readme specifically states "PC Access Version 3.17.3.861 (09/February/2021)- Fixed tool bar and menu icon sizes."SierraTech said:Well, just updated to 3.17.1.856, and Indeed "Setting Time" works (I tested over Serial, my Ethernet is disconnected)!
Now If I can get my failed attempt to resolve "SYSTEM RESET" issue and controller working, I will move to isolate the Ethernet from LAN Flooding issue now that we use IPTV!
What Snaplink issues? I've been running it for years and don't remember any issues. Although I don't update my iOS (version 11.x) and I don't use a lot of add-ons.SierraTech said:Thank you for letting us know! I wish they would refresh iOS SNAPLINK issues, but PCA is definitely most important!
-Bob
Hi I have same exact problem - HAI Omni Pro II I tested PC Acces 3.13,with Win XP 7 And 10 - cant set year 2021ctuinstra said:I'm having the very same issue. This is a programming issue with PC Access. A kind of Y2K issue, the programmers didn't think that it would be used in 2021. I'll bet if you set your PC clock back to 2020, it will work. I would try it but, I don't want to set my controller back that far and not be able to correct it.
Hopefully Levitron hasn't slammed the door on Omni just yet and they will consider fixing it.
Do an update and it should take care of it. It's been fixed for a month or two now.Paul0077 said:Hi I have same exact problem - HAI Omni Pro II I tested PC Acces 3.13,with Win XP 7 And 10 - cant set year 2021
I just checked for new updates and it responded with no updates found. Seems like it's up and working.scorp133 said:I get a server not found error when trying to update from 3.17.0.843, also get an error when hitting https://www.homeauto.com from a web browser (tcp reset from server). Is this an expected outage?
Hi,scorp133 said:I get a server not found error when trying to update from 3.17.0.843, also get an error when hitting https://www.homeauto.com from a web browser (tcp reset from server). Is this an expected outage?
