dadarkjedi
Hello everyone, I would like to ask a few questions about the Elk M1 Gold home security system/ home automation. I purchased this unit about 4 years ago and still have not installed it, its still in the box lol, I know I know, why the heck would I buy it and never install it, well if you happen to read my only other post, I originally bought it because I was having an issue arming my currant system (Guardaware) that came with the house when I purchased it. Well as soon as I purchased the Elk M1, I figured out my problem with the guardaware, lol so there is sat for 4 years, well its time to get cracking.
OK so here's question #1, my old system has what looks like, ball reed contacts on all the doors and windows throughout the house and a few motion sensors, and all have worked flawlessly so far, (knock on wood), Everything is hardwired, there are no wireless items in the system (too old I guess). I plan to run cat6 cable for the new key pads, and I intend to purchase the Elk data bus wiring hub to connect the keypads to the main panel, but I was wondering about the wire that is used throughout the house atm that connects the door/window triggers, and sensors to the old panel, would I be ok to use what's already in place as far as wire goes, since it's all there already, and has worked great all this time, or would I need to replace all that wire.
Question #2 would I need to replace all my door triggers and window triggers and sensors? or are the old items still usable.
Im really not familiar with how these systems work, but I'm up for the challenge, and my primary concern is, I would like to have everything ready before I remove my old panel and install the Elk, inorder to minimise the time the house is without a security system, so I'm trying to get everything in order and replace what ever needs to be replaced, before I change the panels, and purchasing additonal equipment, or new motion sensors and door/window triggers is not an issue if that is what is required or recommended, so any info would be very much appreciated, and Thank you very much for your help.
