I am trying to turn on my RC-80 thermostat to heat mode when the inside temperature as indicated on the thermostat drops below 37 and turn the thermostat off if the temperature goes above 39. In other words, I'm trying to keep the inside temp a few degrees above the freezing point. Unfortunately, the code doesn't appear to be working since the temperature dropped as low as 35 and the heat did not turn on. I verified that the Armed Away Flag is ON
I also did notice that I cannot manually set the heat setpoint below 47. For example if I try to set it to 39, it will automatically reset itself to 47.
I would greatly appreciate any assistance in making the following code work.
100. WHEN Armed Away Flag ON
AND IF THERMOSTAT CURRENT TEMPERATURE IS LESS THAN 37
THEN THERMOSTAT MODE HEAT
101. WHEN Armed Away Flag ON
AND IF THERMOSTAT CURRENT TEMPERATURE IS GREATER THAN 39
THEN THERMOSTAT MODE OFF
