That says use Redmere, but not all active cables are the same. Read Brent's posts carefully. There are things to try if the Denon comes back and there are still issues, if you want to continue to troubleshoot.
I recently replaced a Panasonic plasma TV with a Vizio UHD LCD TV and had problems with the video freezing and losing signal altogether and I used the same cables. The source is a Motorola set top box. I ended up moving the set top box closer to the TV and using a different shorter cable and it corrected the problem.
My point is that the only thing that I changed was the TV so maybe the old Panny was amplifying the HDMI signal or handling it in some better way than the Vizio.
