wkearney99
I'm not asking what'd fit in the can, as much as I'm just asking if anyone's seen or used one yet (or one of equivalent size).
Given the dimensions mentioned in their PDF for it, just about anything that would fit in a typical 28" can would likely fit in this one also.
I'd most likely be putting three RadioRA2 gizmos (2 repeaters and a VCRX) and a WiFi router/access point. The Lutron gear I'd probably put in a ChannelVision wide clamp at one end and the router at the other.
A concern worth considering is the size of the face flange on it. 19.5" wide by 34.1" tall takes a good bit more than the 15.62" wide by 29.32" tall required by the cover on a metal can. The literature doesn't mention the size of the rough opening. But the CAD drawing (DWG) measures it out to have the same width as a regular can (but taller than a 28").
