It seems to me like trying to force a square peg into a round hole.
There are plenty of devices designed specifically for this purpose... measuring power in single and 3-phase circuits.
They are designed to do the whole job, and do it properly. The WC8 and WC32 devices are simply not the "right" animals for this job.
Even with a precision RMS to DC converter, it doesn't give you anything about the phase relationship (powerfactor). It doesn't have the resolution to measure small current or voltage changes over a wide enough range to be really useful.
There are single chip devices with amplifiers, filters and 22-bit ADCs, and enough processor power to calculate true power, powerfactor etc, in real time, across multiple phases, that can run directly from the mains with minimal input and power conditioning.
Rossw is right. I spent 34 years in legal metrology fields and this is not the way to go for power measurement at all.
You will need power factor, phase anglesnd possibly distortion factors which you aren't going to get like this.
In the early days there were people that used a box full of transducers hooked into a multichannel A/D and could do a phasor analysis of a 3 phase metering installation but it was clumbsy and cumbersome,
Later techniques developed that used multiple channel A/D converters to analyse at least 6 inputs (3 currents and 3 voltages) in real time. Before you get any ideas there think of this.
- You will need to sample the AC quantities at least 16 samples per cycle.
- You have six (or preferably more) channels of sampling to do
- At 60 Hz x 16 samples per cycle x 6 channels
we have 5760 samples per second to do. That is 1736 usec to do each sample and save it in a database.
- The samples cannot be staggered for sampling with a scanning A/D multiplexor. They need sample and hold circuitry so they are all simultaneous quantities.
Provided you can get those input requirements met here are some things you can do.
For power (W) multiply each voltage (V) sample with it's corresponding current (A) and average the totals for one or more complete cycles.
For RVA shift one of the quantities (V or A) 90 degrees and repeat above for power.
For VA take the Root( V^2 + A^2)
For PF take VA / W
For three phase VA it can get more complicated than that. You need to know about arithmetic VA vs, phasor VA quantities. Phasor VA will be the most common and easiest to calculate
For three phase measurements much more phasor relationship understanding is necessary for the system to connected properly and measured properly. For three wire systems phase relationships have to be measured for system unbalance in phasing and some assumptions made.
Distortion and harmonics can be calculated with Fourier transforms from the raw samples.
